Strikethrough remains when converting checklist node back into normal node
  • create a node with some text
  • context menu > Make checklist
  • check off the checkbox
  • context menu > Unmake checklist
The text should be reverted back to normal (no strikethrough) when selecting Unmake checklist.
The strikethrough remains, with no way to delete the styling.
Dynalist macOS 1.1.1.10.
In the web version you can remove the strike through by unchecking them item, either with the context menu or Ctrl + Enter. Even if it’s not a checklist item.
In your Steps to reproduce try using the context menu to uncheck the item after unmaking the checklist.
Ah OK, then maybe it’s more a design decision … I really expected the strikethrough to disappear when disabling the checkbox. In my view checking things off made sense only if there’s a checkbox.
