Shift-click in same item doesn't work to highlight/select text
I’m not certain if this is a recent change or if it’s always been this way, but I know but it’s been bugging me a lot recently.
I often want to select some text to delete/cut/copy/whatever. In any text editor I can hold the shift key down and click somewhere to highlight all the text between the current cursor location and the location I click. But when I shift-click within the same item in Dynalist nothing happens.
Holding shift and pressing the arrow keys works fine (text gets highlighted).
Holding shift and clicking in a different list item works fine (multiple items get highlighted).
But holding shift and clicking somewhere in the current list item doesn’t work (nothing gets highlighted).
seems like this is fixed after last update :ok_hand:
Confirmed. Thanks.
