With bold/etc., background color and headings, there are various ways to apply formatting. Which means you can make a mess if you’re doing a fair amount of editing. It can take a fair amount of time when you want to erase the formatting to have to individually select various copy and change it.
I’d like a Remove formatting command that could be applied against selected or node text. Just one command and all the formatting is removed.
Thank you,
Marc
