Redo (CTRL+SHIFT+Z) and Undo commands
I would really like this
Most programs have two functions
  • Undo (CTRL+Z)
  • Redo (CTRL+SHIFT+Z)
Unfortunately dynalist only has the first one CTRL+Z (undo) but not redo
It would make a huge difference since you might accidentally delete something in dynalist using undo and need to “redo” it
related
Ctrl+y ?
i mustve have missed this
I cannot rebind to CTRL+SHIFT+Z, which is what I’m used to though
Got it, will fix this!
Update: you can’t rebind to Ctrl+Shift+Z because Ctrl+Shift+Z is already in effect. It’s just that Dynalist can’t show two shortcuts for the same action.
Can you give it a try?
it works thanks erica
had to bind it to
SHIFT+Z
before I could bind it to
CTRL+SHIFT+Z though
I meant you don’t need any binding at all to use Ctrl+Shift+Z, that’s enabled by default (this is why you can bind to it – it’s already bound to it).
You can bind to Shift+Z and then to Ctrl+Shift+Z, or you could remove the binding altogether.
