Quick way to filter tags when using Ctrl+F (search)
duplicate
A handy feature in Workflowy – when a search begins with a tag symbol – # or @ – a list of matching tags pops up that filters as you type.
For example – search for “#f” and you’ll see a list of all tags that start with “#f”. Type another character such as “#fa” and the list filters down to just tags that begin with “#fa”. This is very fast and easy to use.
It is much faster to use than the Tag List pane in Dynalist.
Please consider this as a feature request.
Thank you!
dgg
bump…
Hi David,
I’m sorry that Dynalist still doesn’t have this. This has been a rather popular feature request since a long time ago.
The main feature request post is this one: Autocomplete tags when searching
I think it’s the same as what you’re requesting, although worded slightly differently.
Sorry for still not having it in Dynalist. But I recommend bumping that one instead rather than starting a new one, thanks!
Thank you! I missed the other thread in my searching, but I will add my comments there.
Thanks again!
