Quick way to add an item
This is a ridiculously simple technique, but I’ve found it helpful with daily Dynalist.
I often find myself in the middle of an item’s markdown text. To add an item requires me to carefully position the cursor at the end of the item and then press return.
A PhraseExpress macro with {#END}{#ENTER} tied to a hotkey eases the flow.
One day, we’ll have WYSIWYG, but in the meantime…
Another way to do it is
Ctrl + End
Thanks. That shortcut seems to take you to the bottom of the screen, which is useful in it itself. But I’m looking at adding an item immediately below the current item.
This is nice but I think it won’t work if the bullet has multiple lines (I think yours will just take you to the end of the line, but not the end of the bullet?) - A foolproof method is:
Ctrl + a -> right arrow key -> enter
This will always work no matter how long the bullet is (and of course, left arrow key to add something before the bullet)
