Write a sentence longer than one line in note in Chinese.
Toggle note to show just 1st line, then it will show 1st line.
It cut a bit of the upper part of text in 1st line, and showed a bit of the upper part of text in 2nd ine.
(It seems my screenshot was always compressed when uploading.)
Android app version 1.1.17
