Possibility to lock documents or code segments?
Good Day Everybody,
I really love dynalist. But there’s one thing that’s holding me back from further personal adoption. I keep a lot of technical notes such as code snippets and commands to run in the terminal. I usually mark code snippets with the backward ticks. But when I go to copy the code snippets I click to copy and I move into edit mode where I see a command like so `useradd tacoguy`. I then have to fight with the backticks. The solution thus far is to just not use code segments but then the document looks worse and they aren’t as distinguishable. Especially for commands that write more like an English sentence.
Is there anyway to get around this or to even better lock the documents kinda like a Google doc on mobile where you have to click a button to modify.
Thanks so much
Hi @TacoGuy,
The good news is that the mobile version has a Lock Mode where you can’t edit stuff. The bad news is that it’s not available on web/desktop unless you resize or zoom in enough to trigger the mobile layout. Even in that case from my testing it doesn’t work well enough for web/desktop since it’s designed for mobile.
Maybe we can port that over and improve it for web/desktop. Sorry for the inconveniences for now!
P.S. Love :taco: as well :slight_smile:
Thanks for the reply Erica. I think it would be a great feature. Maybe an option in settings.
