Pasting images appears to be broken
fixed
ETA: This appears to only be an issue for a certain website, so it might be difficult to reproduce.
Copy an image from one website, then paste it into Dynalist as usual.
The formatted hyperlink to the image should eventually show up.
nothing visibly.
Chome/Win10
It works on other websites, and the madebyevan clipboard test.
This should be fixed in the latest versions (please refresh/reload the app to update), could you please confirm?
