Hello. First off I want to say how much I like Dynalist. It is my constant companion during my work hours.
I have a suggestion. Right now it appears that if a parent has a check box, all the children do as well – am I missing a way to turn that off so that children don’t have the check box? If I’m not missing something, then I’d like to suggest you add this option, because more often than not the sub-items I add to a check box item are notes about that item, not sub-tasks.
Thanks!
