Move while zoomed in doesn't work
  1. Zoom in on an item with sub-items
  2. Activate (edit) the top-level title item
  3. Check the item menu for the Move function
  4. Try the keyboard shortcut for Move
Able to move the item Iā€™m currently working on to another document
The Move function is not in the menu and the keyboard short-cut doesnā€™t work. Only the sub-items can be moved. The title item cannot be moved.
In order to move the title element you have zoom out at least one level.
Chromium (SRWare Iron) version 55.0.2900.1 on Windows 7
When the title element is the document title I can understand why it canā€™t be moved. But when zoomed in on an item within a document I expect to able to move it.
Thanks.
Hi @Schultzter, sorry for digging this up :grimacing:! Weā€™re cleaning up the bugs.
Sorry for not replying back then, it must have fallen through the cracks somehow. Now that I look at the bug report, it seems more like a feature request than a bug. Moving the place youā€™re current on implying changing the entire context (going into another document, essentially), so Iā€™m not sure if everyone expects that to happen.
