- Create an item, let’s call it “Trip to France”
- Decide what you want to pack there, make some other notes and check the item as done once you actually visit this beautiful country.
- After some time decide that you want to go there one more time, make another item with the same name (“Trip to France”), possibly in a different place of your doc structure
- Go somewhere else in the doc, create or point to another element (like “pack a toothbrush”) and use move shortcut (Command+Shift+M on Mac), search for “Trip to France” where you want to place the pointed element.
The previously checked “Trip to France” should not be visible on the list or should be clearly marked as checked (depending on your settings).
Both “Trip to France” checked and not checked are shown in exactly the same way, if you choose the wrong one your “pack a toothbrush” element may go to the checked element that you probably never read again. Particularly if checked items are not visible your note is basically lost.
Browser, Chrome on Mac but it probably doesn’t matter
N/A
