I am looking for a way to search for all items with a specific hash tag, and then to move all or several of these items at the same time.
Search for the tag, cut copy paste wherever you want.
That does not work. For instance, a certain tag search gives me 14 results from 8 different documents. I can not select several of the results in order to cut copy paste them. If I select 1 result, it simply clicks through to display that one result – which I can then cut copy paste, but that is not what I’m looking for.
Don’t search universally then. Search per document basis. That drag select all the search results and cut copy paste.
I don’t think there is any other option. There might be for Pro users that I’m unaware of though.
Thanks for the suggestion, but the idea is not to have to go through multiple documents.
