Chrome: Hitting my hot key combo for move does nothing. It has worked before. Going to the item menu and selecting move likewise does nothing.
THE MOVE dialogue.
I SEE NO MOVE DIALOGUE.
Latest ver DL, latest vers Chrome, latest mac OS.
This has worked reliably in the past. Refreshing the tab for DL or closing and reopening does not make a difference, same results. No move dialogue.
