So out of boredom, I made a sketch [1] to propose some interface change on mobile [2] interface, mostly involves swiping up/down so two function can be fitted into a icon. For example, on the red-highlighted icon, swipe up to redo and swipe down to undo [3], same applies to functions like navigating between objects [4] or increasing/decreasing indent, except last 2 interface which is simply a click, for adding notes and deleting the object. Oh, and having undo/redo function besides keyboard could make stuff little easier to reach too.
The cogwheel icon on top left could contain more features which is only available in desktop like numbering children; adding options like “expand/collapse all” and “duplicate object” would be beneficial to have too. Also… Does mobile feature feature tag pane function like it does on desktop platform?
Apologizing for suggesting too much but just want to leave some ideas to optimize Dynalist for mobile platforms.
ALTERNATIVE REQUEST
Holding the node could show these options:
Some of the toolbar functions could be moved into “holding-node” options like: highlight colors, heading format, make checklist; also needs copy/duplicate node function.
While the rest of the toolbar could have some little change and rearrangements; and removing some options that already exists in mobile version like expand/collapse (individuals) and zoom in/out.
FOOTNOTE
1 - Its a sketch so expect low quality PNG.
2 - Also this could be applied to tablet interfaces.
3 - Undo/redo is moved from the interface top to toolbar instead.
4 - Also a new function for mobile platform, since navigating vertically between objects can be little difficult on a small screen.
