- open 2-5+ notes and fill them with a long texts (letās say atleast A4 length)
- open the full view of all notes āalt+nā
- at first just click in between the notes
-especially when you have just one fully visible (to find out the problem sooner) - secondly try to select the text in between the notes
-again especially when you have just one note text fully visible
The problem is happening mainly when you donāt see the full length of the note (the note is longer than your screen).
- expecting to not lose cursor/focus ever when working on multiple note texts
- expecting to select the text of the other note fast and without the ājump/fullnote selection effectā
- expecting to find the cursor in a place i did place him (sometime the cursor ends at the end of the note section for no good reason)
- loosing the track of the cursor when changing (click) the possition from one note section into another (when the note text is long or not fully visible)
- same when try to select the text in the other note field
- sometimes the cursor ends up at the end of the note field for no good reason
Windows 10 pro
Chrome
Thanks a lot for repairing this issue. I love the fact I can have all the notes open and work simultaneously on all of them. But with this issue, itās super annoying (breaking the flow a lot and very often).
Update: Recorded a video, where explaining the issue
