Live demo doesn't work
https://www.dynalist.io/demo/ doesn’t seem to work.
I can’t open any documents and this error is shown with JavaScript Error notifier chrome extension:
This is on latest Chrome on latest Mac OS X.
Can’t repro, can anyone else repro this error?
Note: this is in logged out state.
Also, right now Google login doesn’t work:
There are also bunch of other errors on the console:
Yes, I tested while being logged out.
Any chance Google is somehow blocked in your region?
I’ve debugged this and your servers are misconfigured.
Show this to your programmers:
The code that is failing:
        t.prototype.init = function() {
            var t = this;
            gapi.load("auth2", function() {
                gapi.auth2.init({
                    client_id: DYNALIST.GOOGLE_LOGIN_PUBLICKEY,
                    cookiepolicy: "single_host_origin"
                }).then(function() {
                    t.google_loaded()
                }, function(e) {
                    "idpiframe_initialization_failed" === e.error && e.details.match(/Access is denied/) ? t.google_error = 'Google sign-in doesn\'t work if you turn on "Block third Party cookies and site data". The setting can be found in Settings > Show advanced settings > Privacy > Content settings.' : t.google_error = "Google sign-in doesn't seem to be working",
                    t.google_loaded()
The error returned from Google is:
{error: "idpiframe_initialization_failed", details: "Not a valid origin for the client: https://www.dyn…itelist this origin for your project's client ID."}
details
"Not a valid origin for the client: https://www.dynalist.io has not been whitelisted for client ID 744346888110-sijqhh7ubgtgjfma0j0bicgq544l90f6.apps.googleusercontent.com. Please go to https://console.developers.google.com/ and whitelist this origin for your project's client ID."
error
Not a valid origin for the client: https://www.dynalist.io has not been whitelisted for client ID 744346888110-sijqhh7ubgtgjfma0j0bicgq544l90f6.apps.googleusercontent.com. Please go to https://console.developers.google.com/ and whitelist this origin for your project’s client ID
Means that the project is misconfigured in GCE.
I’m using it from https://www.dynalist.io/.
Maybe you’re testing using some alternative domain.
@Shida Could you take a look at the stuff he sent?
@Krzysztof_Kowalczyk It could be something wrong on our end, we’re going to take a look. I wonder why most of our users are still logging with Google just fine though, the issue might be a mix of your client and our configuration. We’ll see! Thanks for the detailed report.
#7
Oh I see the problem! Dynalist is usually served from https://dynalist.io and not https://www.dynalist.io
Not sure why this isn’t happening but we’ll make sure to setup a redirect from www soon to fix this! Thanks again for the report.
