on https://help.dynalist.io/article/75-convert-between-items-and-documents
it uses the term ‘document pane’ but this term doesnt seem to be used anywhere else
what’s a ‘document pane’
on https://help.dynalist.io/article/81-export-list-or-document
there seems to be a distinction between ‘lists’ and ‘docs’ tho not sure what that would be
If you’re exporting a list, open the item menu and choose “Export…”. If you’re exporting a document, right click on the document and choose “Export…”.
what’s the distinction? i dont see it anywhere, seems hard to find
it would seem more efficient overall and simply overally better if any gifs or images or updates or something were updated to these pages for longterm
