Larger Custom CSS window in Pro settings, or ability to drag a corner to enlarge it
Hi all, one small nitpick is that the window for custom CSS in the pro settings is pretty small, and since I have a bit of code there I have to scroll a lot to find the part I am looking for. If the window could be taller, or if there could be a handle to drag a bottom corner to enlarge it, that would make it much easier to navigate.
Hi Dave,
Sorry that we havenā€™t made this clear anywhere, but we encourage you to edit the CSS in a dedicated editor, ideally where it highlights CSS properly. Then you copy paste to the window. So the window is literally big enough for you to paste stuff in.
Does that help at all?
ok, will do.
