iOS external keyboard shortcuts for zooming don't work
Press Ctrl-] or Ctrl-[ on any item
Zoom in or out
Nothing happens
iOS 11.4
Dynalist 1.2.7
Keyboard: Logitech K380
Maybe related:
Ctrl-Shift-Backspace, Ctrl-. works.
Ctrl-Shift-M doesn’t. (reference)
My own custom Ctrl-Shift-J works.
Thanks for catching this!
We have tracked this bug on our todo list, and will fix it as soon as we can! Thanks again for letting us know. I’ll update here when it’s fixed :slight_smile:
We’re sweeping bugs recently and investigated this bug.
If you’re using an iOS device, these shortcuts do work, but you will need to use the “Command” key instead of the “Ctrl” key. This follows the same convention as MacOS where all shortcuts that uses Ctrl on Windows and Linux and reprogrammed to use Command instead.
