Press expand/collapse bottom in iOS app.
Expand/collapse list
Need to press multiple times for the function to work.
Using iOS app, try change list density and font size make no difference,
Had same experience when use phone browser, was hoping iOS app will fix it. I donāt have large hands, but seem like the expand/collapse bottom is too small or something (never have this problem with other apps), āalmostā always have to press three to five times just to expand or collapse lists.
Thanks for create the app.
