Invisible Dynalist window?
Iā€™m a bit concerned that its a setting on my computer that caused this, but I canā€™t come up with a solution myself and this is literally the only program it happens with, so I figured Iā€™d post here.
  1. Open Dynalist windows app
  2. The program is invisible even when its in the foreground.
See the Dynalist program and be able to interact with it.
I cannot see the window at all.
Which operating system are you using? Which browser are you using? If youā€™re using a desktop or mobile app, whatā€™s the version number of Dynalist?
Windows 10, Surface Book 2015.
I have this issue both with and without my external monitor.
As you can see in screenshot 1, The program is in the foreground, but not displayed.
The only workaround that I have found is turning on tablet mode on and off, which makes Dynalist visible.
Hi @R11, could you try the steps suggested here and see if they help?
https://support.microsoft.com/en-us/help/181691/some-programs-are-displayed-off-the-screen
Hi Erica,
Thanks for the help and apologies for taking so long to reply. This solved my problem! :slight_smile:
Great! No worries about the delay. Iā€™ll close this bug report then :slight_smile:
