In Mac OS (from either dynalist in safari or the app). a link from Dynalist will open another app on the computer eg: marginnoteapp://note/XXXXX will open a pdf at a specific point in the marginnote app. However a link to a specific file e.g. file:///Users/my _username/Desktop/rota.pdf keeps me in dynalist with a âNo document is openâ dialogue
I should be able to open local files using a link from Dynalist. This works OK in Workflowy and Evernote.
