How can I print notes? I’m hoping there is a way to choose if you want notes printed or not. Thanks, Ray
Are you using the web version or the desktop app?
You can print just like how you would normally print a webpage. The shortcut is Ctrl+P
normally. You could set notes to hidden and then print.
