I tried putting some blackslashes in, but that doesn’t seem to work. Is there a was to display __my text__
, but as normal text?
Unfortunately, Dynalist doesn’t support Markdown escaping right now.
Are you trying to write the name of a Python method of something? The closest workaround I can come up with is to write __text__
(surrounded by grave accent for code) instead as these two formats do not nest.
I see. I was actually importing my collaborator’s text from somewhere else, and they were using underscores to indicate blanks in a word.
Ah, ok. Still, sorry for not being able to escape Markdown right now.
Update: you can escape Markdown with \
now.
Thanks!
Not so sure about that:
I see the underscores but i also see the escapes.
P.S. wish dynalist could paste images like this forum can.
