Hover icons while in article view misaligned
  1. Open a file.
  2. Change the viewing mode to article.
  3. Change the list density to compact or comfortable.
Expected the icons that appear when mouse hover an item to be aligned.
Icons are misaligned.
  • Bullet point to zoom in: Enabled. List density: Comfortable.
  • Bullet point to zoom in: Enabled. List density: Cozy.
  • Bullet point to zoom in: Enabled. List density: Compact.
  • Bullet point to zoom in: Disabled. List density: Comfortable.
  • Bullet point to zoom in: Disabled. List density: Cozy.
  • Bullet point to zoom in: Disabled. List density: Compact.
Web dynalist. Chrome for linux.
Thanks for the bug report!
Unfortunately article view is not a big priority right now – we’ll fix it when we have time to. Hoping to polish up Article View and present it alongside mind map view in the future :slight_smile:
Hi @AnakimLuke, sorry for digging this up :grimacing:! We’re cleaning up the bugs and would like to know if the bug is still happening to you? If not we’ll close this bug :slight_smile:
