Help! I can't rename tags anymore
I am going in to rename tags by right clicking in the tag pane
I expect to see a Dynalist right click menu that allows me to rename the tag
Instead I get a browser right click menu, not the Dynalist right click menu
I am using a Macbook Air with MacOS Sierra 10.12.6 and I am running Dynalist in a Chrome Broswer v63.0.3239.132
Sorry to hear that!
You mentioned ā€œcanā€™t rename tags anymoreā€, so it used to work for you before? Did something change? Like did you install any new add-ons?
From our end, we didnā€™t make changes to this recently, and from my brief testing it seems to work.
I see in the screenshot ā€œDEADLINEā€ seems to be selected, was that automatically selected by the browser?
I can reproduce this, but for me it only happens for tags listed under # All Tags!
It does, however, work like expected for all tags under # Document tags.
Hi Lucas
Since posting my query I have found the same. A rename tag function across all documents would be handy but I can work within this limitation.
Thanks for getting back to me and thanks for your work on Dynalist. It is the centre of my working universe and I couldnā€™t live without it now, I think.
Hi Peter,
Yeah, thatā€™s whatā€™s happening. Renaming currently only works on document-level tags, sorry about that!
And thanks @Lukas for being awesome again!
Any plans on fixing this? Isnā€™t ability to rename all tags the priority?
Not yet, sorry.
Although easy to implement for us, renaming potentially thousands occurrences through all your documents is quite risky. The undo/redo model we have right now only works reliably within a document.
I understand the need to rename tags across all, making sure the process is undoable is also an important part. Sorry about the delay!
Sure, just to add some context - this is what Iā€™m dealing with.
Coming from Workflowy, which ignored Case. There are many of these duplicated throughout the 838.
Itā€™s honestly made tags pretty redundant in DL (luckily, I hardly used them).
While Iā€™m at it - is there any way to sort alphabetically?
Yes, you can sort them using the A-Z button at the top of the panel:
Ah, that was obvious, thanks!
EDIT: Another weird quirk -
Most likely these ghosts are hidden by some filter (e.g. hidden because theyā€™re checked).
Is that the case for you?
Iā€™m sorry, I donā€™t know what you mean.
Try changing your checked items to ā€œshowā€ and try again. Like this: Incorrect Tag Counts?
It might not be your problem thoughā€¦
Oh right you are, yes they were hidden. :ok_hand:
I came in here because I was experiencing the same issue, and didnā€™t understand why the Rename menu wasnā€™t being shown. If this function is only going to work in Document tags, under All tags it should at least do something useful for feedback. Showing the browser menu in that case is pretty useless and looks broken, perhaps instead it can show a disabled menu that says something like ā€œTag operations are only supported for Document tagsā€? That would serve as a reminder for where I as the user am going wrong.
Will add one, thanks!
