Getting error: "Failed to load documents."
resolved
when opening my account i get the error “Failed to load documents.” and it doesen’t display my notes.
i’m suppose to see my files
it circles and displays error “Failed to load documents.”
windows, google chrome web version
Sorry for the late reply!
Are you using Dynalist in your workplace or something like that?
The only reason I think that would Dynalist being blocked somehow.
Are you consistently seeing this error?
i tried from home, it was resolved somehow 2 days ago, thank you for reviewing this issue
Thanks a lot for the update!
It’s most likely some sort of connection issue – glad it’s resolved! Please let us know if it comes up again.
