NOTE: this is what this post is about.
Hellooo! Been away for ages but Iāve got some new suggestions
I think this has been mentioned before, but I think that the panel showing folders and documents could be improved slightly.
Depending on how people use Dynalist, some may have a single document, like Workflowy, where every ādocumentā is a node somewhere in it. Others, like myself, may have lots of folders and each separate topic is in itās own document.
Hereās the compromise in my view. The second way is less flexible, because you cannot control the folders and documents the way you can a list. You canāt collapse all, or expand a document straight away etcā¦ The flexibility isnāt there. However, you can share each document, whereas with a single document you canāt share individual nodes (this should be a feature too imo).
One way I have tried using is having a separate document which has links to all the other documents, but this feels clumsy. SO, finally, is there a way you could make the document/folder panel as flexible as a list?
Great job either way
