Field of view does not update when selecting more than one bullet point
fixed
Select one or more bullet points in a list using shift+down or shift+up. Move the selected bullet points up or down the list off the screen.
Screen updates to keep the selected bullet points in view, like it does if you are simply moving one bullet point at a time.
Bullet points disappear from view; screen does not update.
Linux, Chrome and Firefox.
Screen also does not update when selecting items that go off the screen. IE, there is a long list that goes off the bottom of the screen. Move to near the bottom the screen and press shift+down several times until you’re highlighting items that are off screen. Screen does not scroll to show you what you’re highlighting.
Hi @Mark_Eichenlaub,
I was able to verify the behavior myself. It seems that it has always been this way; we’ll fix it when we have the time to do so.
Thanks a lot for the bug report!
@Mark_Eichenlaub: This should be fixed in the latest versions (please refresh/reload the app to update), could you please confirm when you have time? Thanks in advance!
Yes! I noticed that a little while ago. Thanks youQ
