Export Plain Text defaults to Spaces, even when another style is shown as selected
fixed
  1. Create a basic list of items, length irrelavent
  2. Choose Export from the floating hamburger
  3. In Export dialog, choose Plain Text, and either Asterisks or Dashes
  4. Close dialog
  5. On the same, or another list, go to Export Plain Text
  6. The export preview will show spaces formatting, but the dialog has your previous style still selected
Export dialog should correctly style the exported data based on the style previously selected, and which is still shown as selected in the dialog
Export dialog defaults to spaces despite the format style selector having your previous style still selected
Win10, Chrome 61.0.3163.100
First export:
Next export:
Love the product, it’s been a wonderful experience after Workflowy. This is a tiny problem but incredibly annoying when you’re trying to repeatedly copy exported data into another application.
I can reproduce and confirm this bug – thanks a lot for reporting! Very nice catch! :slight_smile:
Will fix as soon as we can!
Should be fixed now, could you confirm @Joel_Madigan?
Last call @Joel_Madigan , will mark as resolved if there’s no response. Verified fix on my end :slight_smile:
