Exclude completed item tags from tag pane
I’m loving the new tag pane, and the ability to sort the tags!!!
However the tags on completed items still show up in the tag pane, which muddies the value since the list is polluted with tags that aren’t entirely relevant. Not completely irrelevant either.
So it would be nice to have a toggle to exclude completed item’s tags, at the top of the tag pane where it’s quickly accessible. I use my tags for projects (hash-tags) and people (at-tags) so if there’s no tags in the tag pane then it would mean I have nothing to do right now for that project or person!!!
Tags for checked items
Maybe a bookmarked search will get you close to what you want:
The query is:checklist -is:completed will show you all unchecked items.
If you run this query from within your project root item and click on the star next to the search box, the bookmark created will even remember the item you ran this query from and take you there automatically.
If your projects are all nested under a common root item, you can even run the query from there to get an overview over all projects.
