- Get the link of a bullet point.
- Delete the content of said bullet point, without removing the bullet.
I guess it should have the link symbol and some blank space.
A blob of what might be a link, with no icon.
Windows 10 / Chrome Stable
This is sort of similar to this one. Can't leave image description empty
