Awesome, thank you!
When is this coming to Firefox? With their new WebExtension format theyâre pretty much identical to Chrome Extensions.
Soon, thanks for the suggestion!
Thanks for this simple and useful tool. One thing though. I find the default options to be less than optimal. Iâm using a setup that only uses ânoteâ for the selected text and makes the Title linkable.
BTW: I did this because I couldnât get linkable text in the note to work.
What do you mean? Itâs the same format ([%title%](%url%)
Let me put it another way. Linkable text in a note doesnât work for me, so I changed the formats to something that turns out to make more sense to me anyway.
Obviously, I know how to do linkable text, but thanks for trying to explain it to me regardless.
Ah, got it, so itâs working but you felt like it doesnât suit your habits/needs?
No. It doesnât work.
Back to the original: âI did this because I couldnât get linkable text in the note to work.â
I used âfor meâ in my reworded statement just in case my particular set up doesnât work. Though I doubt that. I believe it doesnât work for anyone. Have you tried it?
Oh, are you using with or without selection?
This is what I get with that setup:
OK. Got it. The problem is that I had notes hidden. The only time I see them is when cursor is on the line. So, of course, the link syntax is visible then just like in a normal list item. I changed notes to âshowâ and the link is back. Thanks for talking me through it.
I see, thanks for the explanation.
Hiding notes would make this part unusable for you, unfortunately. Please use whichever format that works you then!
Hi the clipper is great but when I send clip current page to dynalist from the right click menu there is no indication that anything has been sent (it has been, but it would be good to see some confirmation)
Hi Malcolm!
We actually thought of doing that back when weâre making the clipper. The unfortunate thing is that it seems that itâs technically impossible to trigger the same popup for confirmation purposes after successfully clipping something
Weâll take another look!
Thanks fro looking at this. Like I said, it seems to be stable and I havenât had the case of sending items to my inbox and them not arriving ⌠but I love and confirmation that can be given
Yup, thatâs definitely very understandable!
Hi Erica! This extension is great, thanks Any chance to include an option to add tags? The cherry on top of the cake would be picking from my list of tags, ideally with a âsearch as you typeâ
Unfortunately that would require the extension to get the tag list, which would be kind of slow. Or it would require running a full Dynalist page in the background, and that will take lots of memory Itâa a great idea for sure but there are some technical difficulties.
So for now, youâll have to remember your tags if youâre gonna add them. Sorry about that!
