Devonthink URLs Not Working Properly
fixed
When embedding Devonthink URLs callback links into Dynalist, they have worked until recently. The URL is no longer properly formatted when it launches in the browser. It appears that the colons are missing such that this link:
x-devonthink-item://1F6876C9-B5C0-4424-9CA3-7D0C2AB7A0E6
becomes this link:
x-devonthink-item//1F6876C9-B5C0-4424-9CA3-7D0C2AB7A0E6
and the URL won’t launch.
I’m not certain if this is a broader issue with URLs as these are the only ones I use in Dynalist.
The URLs work properly on iOS, but not on web app or Mac app.
I think this is broken in a recent update in an attempt to fix local file links. Will fix as soon as we can!
Thanks a ton for letting us know :slight_smile:
@John_Cromwell: This should be fixed in the latest versions (please refresh/reload the app to update), could you please confirm when you have time? Thanks in advance!
It works!
Thank you!
John
