Shift-command-delete to delete a line
Cursor lands at the beginning of the item after the deleted one.
Delete lands at the end of the previous item.
MacOS 10.12.6
Chrome, up-to-date
I understand why the expected behavior is the way it is, BUT, if it did this instead,
- I could easily do a series of Deletes in a row — hard with the current behavior
- or I could start a new item by hitting enter
