Ctrl shift and H in Firefox opens history when toggling header formats
Yes I too don’t really enjoy the move away from using CMD+OPTION+1, 2 or 3 to change H1, H2, H3. This cmd+shift+H option is really frustrating and inconveniencing — please consider changing it back!
oops, I take that back. While I now have the explanation as to why the ctrl alt 1 2 and 3 don’t work, there is still the issue that in Firefox in Windows at least, Ctrl Shift H causes the library window to open up, showing the history of pages and other items. So the issue is not resolved. This is not a workable solution.
Is that because the history manager pops up or because you’d like to use the history manager with Ctrl+Shift+H?
Got it. Will prevent default action on browsers.
@Dave_gifford, sorry for digging this up, we’re cleaning up the bugs and would like to know if the bug is still happening to you? If not we’ll close this bug.
Close the bug, I am not getting the history panel when I do Ctrl, shift and H. Nothing happens, which is now what is supposed to happen.
