Type a paragraph of text into a note section in Dynalist. Copy and paste this into Microsoft Word.
Text copied over without weird wrap around (Described below)
Screenshot below
Windows 10 (Tested across two different computers) - Chrome web app
I am able to get rid of the problem by copying first to a plain text editor, then to word.
