Have some nodes with has checkmark boxes
That i can check them off in Mobile
Itâs zooms in instead to Check Off the Checkbox
iOS 10.3.2 itâs not working on my iPad or iPhone
Also when i change the mode on only Viewing on Mobile it reacts the same, hope this simple to fix
