Capture to mobile almost never works on first try
Use “share to” link on mobile from either Twitter or Safari or Flipboard, choose Dynalist, opens app, click Add
Should see confirmation to capture to inbox
Probably 95%+ of the time, it says capture has failed, if I repeat the steps, then it works
iPhone iOS 11.4.1
Dynalist mobile (can’t find version, it should be the latest)
Safari on mobile
