Bulk formatting toggles items individually
fixed
Out of a few items, make one bold.
Select all the items.
Press ctrl-B.
I would expect all items to become either bold or not-bold, perhaps depending on whether the first item was bold or not.
Each individual piece of text was toggled, so non-bold text became bold and vice versa.
The (incorrect) behavior is the same when pressing ctrl-I to make things italic.
On the other hand, pressing ctrl-shift-C to add/remove checkboxes behaves as expected.
I understand the logic underlying the current behavior, but:
  1. It’s probably not consistent with most users’ expectations. All text editors and word processors I’m familiar with exhibit the expected behavior I described above, where everything is made consistent (bold or not-bold) before toggling.
  2. If you have inconsistent formatting in an outline, it’s hard to make it consistent because you have to format each item individually.
Good point, I remember seeing this behavior.
We have tracked this bug on our todo list, and will fix it as soon as we can! Thanks again for letting us know.
@Herb_Caudill: this should be fixed now, could you confirm please?
Perfect, thanks!!
