Hi,
I’m working to find a good workflow to create slides, using dynalist as an outlay for my presentation.
I mainly teach and want to use dynalist as place to store/arrange/adjust my lectures (since dynalist super fast/good^^)
Is anyone else using dynalist to manage lectures?
Not sure, what my workflow is going to be and looking for inspirations/ideas/experiences
Current Ideas
Layout Presentation (the steps/point) in dynalist and then copy/pasta to keynote/powerpoint/googleslides/slidebean/haikudeck/etc.
Might be cumbersome, but dynalist seems for me the best place to arrange quickly steps/ideas -
Layout Presentation in dynalist and then try to automate somehow to deckset (a mac automated slide creator using markdown text), like described here Presentation Mode
But it don’t seem to be easy/me not having good regex skills/scriptings skills… (more a video guy…) -
Skip dynalist and go straight to powerpoint/keynote/etc and make everything there
Skip dynalist and powerpoint/etc and go directly to a markdown text format and use deckset directly
Anyone have had this situation and has any ideas/experiences?
Is maybe something planned from dynalist to share the list visually pleasing using slides?
Deckset might be close, since it uses markdown to generate slides
What would you suggest?
I want to create many mini-lectures, using pictures that might get adjusted over time
Thank you so much for any advice
