Select a line then hit command+b, command+i, and command+b again.
command+b a second time should remove bold formatting
adds bold formatting twice
MacOS 10.12.6, Dynalist 1.0.49
Sorry for the late reply!
I see what the issue is. Currently if you do Cmd+B when the closest formatting is bold, it will remove bold formatting. It doesn’t work when there’s a format in the way though.
This bug has been tracked and we will fix it as soon as we can! Thanks again for letting us know.
