It works - I so far have email, Alexa, Google home, and Google watch sending to dynalist inbox.
You click make your own applet since there is no recipe since you have to paste your personal API key in.
Make an applet then click THIS and choose something like email or Google assistant or anything, then fill out the form, itâs straightforward.
Then it will let you click THAT and you search âWebhooksâ and thatâs the form I screenshotted. If you Google dynalist API documentation youâll find your API key, itâs a long string you copy and paste like fjg74jrbdowjtbf7tbrkaifbrj.
Try it, hopefully I described it well enough and you donât get stuck.
