A suggestion about menu extension in android system
in android 7 and it’s after version, android system provides a menu to enhance the text experience. If you select some text in a text box, it would show up an menu including copy, paste, cut, select all and some other option provided by other app, such as google translate provides a TRANSLATE option in that menu.
Would it be possible to provide an ADD TO INBOX?
